All,
We are so happy with our new anchor that I felt compelled to share it with all the brats that might apreciate a really good anchor.
I made up a pattern and copied the design from a Wisconsin DNR net anchor when we (MNDNR) worked on a cooperative project with them a few years ago.
It is a very simple double claw design made of steel bent to some very exact angles. The anchor is easy to deploy and set and holds like nothing else I have ever used.
The first one I made was for my wifes pontoon boat. We always find the walleyes biting best when the wind blows and had been blown off the fish too many times to count using more conventional anchors. It was made of 1" steel rod and two small pieces of 1/4" steel plate. It worked so well that when "Osprey" came to live with us, I made a second more improved model from 3/4" and 5/8" stainless steel. Materials for the first one cost about $15.00. Around $50.00 for the stainless one. Anyway you look at it that's cheap for a good anchor!
They are 29" long, 22" wide and have a 17" "bite". I haven't weighed the first one but the stainless one weighs in at 18 lbs.
I machined a fastening clip from a block of hard black plastic by drilling a 3/4" hole in it and then cutting it off above center. The anchor just snaps in place when hard downward pressure is applied. The block was bolted into the factory anchor fairlead with two 1/4" stainless bolts.
I have updated Osprey's album with a number of pictures.
Capt Dan
Capt Dan
