Hey all,
First, thanks in advance for any and all input. I have twin '06 F60TLR's on my Venture. They have just over 300 hours and had their 300 hour service. I just purchased the boat 3 months ago and am having serious frustrations and now lack of trust in the outboards. For the first couple months and 50 hours later things were perfect. Then a couple weeks ago the trim/tilt switch got corroded on the port engine and fried the relay, trim/tilt motor and battery. $1000 later...
Now, after having the work done I replaced the port battery and trickle charged the starboard. Hooked them up and fired up the starboard engine. It turned over instantly. Checked the voltage on the battery to make sure the alternator was working. It was. Turned it off and went to restart...click...click...click...
Battery reads 12.60V and the terminals are clean. All fuses are good. The battery connection at the starter solenoid under the cowling reads 12.60V and does not change when the ignition is turned over. The click is not coming from the starter or starter relay/solenoid. It's near back more towards the transom. Port engine starts fine. I'm assuming the starter is fried. Anything else to troubleshoot? Any reason why it would just die after having zero issues or hesitation? With all the back to back issues on both engines my trust in them getting me home is waning...and they are just barely broken in...
Any input would be great.
Thank you in advance,
Troy
Troy
