Active member
- Joined
- Sep 30, 2006
- Messages
- 4,698
- Reaction score
- 23
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Vessel Name
- 'Au Kai (Ocean Traveler)
Three problems with ours:
1. Had I designed it, I would use the small, bungee loops all the way around the bottom vs. snaps. Ours only has the bungee loops on the center rear panel. It's easy to install, in the heat of summer, when the Sunbrella is loose/stretched (but that's not when you need it). In the winter getting all the panels on, snapped down and zipped can be frustrating to say the least and maddening to say the most. One of our zipper's stitching blew out and getting the snaps on the bottom snapped can result in a sprained thumb. (Ours came with the boat, so I had no say)
2. I'd make it taller. I'm barely 5'10 and I just clear the highest point of the frame. Anyone taller would have to hunch over, and that gets old. Again, ours came with the boat.
3. Getting in/out of the cockpit with it installed can be a PIA. I added straps/snaps so I can at least roll up the front two panels and they stay put. But even then, you've got to be pretty limber to do it easily and gracefully...and remember, I'm barely 5'10. The Admiral is a tiny 5'2 and makes it look easy.
