Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,865
- Reaction score
- 211
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
forrest":2dfqktjq said:I would have agreed with you if you had included alcohol in your statement as we all know alcohol has both physical and psychological dependence at rates hundreds of times greater than marijuana. I wouldn't mind breathalyzer checks for the registered boat owners upon return to the boat launch.
That is a puzzling response, considering your post about a sign on your boat--because I left out alcohol, you don't agree with what I posted-- but you would if I had mentioned the evils of alcohol?
I am probably more aware of the problems of alcohol (and mind altering substances) than most, having worked in charity hospital emergency rooms a number of years, practicing medicine for over 30 years and helping with a few marine accident investigations. I left alcohol out, since it is entirely another topic, and should not be equated with marijuana. I don't think that the average person has any concept of the problems with chronic alcoholics--The DT's, death with cirrhosis of the liver, massive intractable bleeding from esophageal varicose veins. Add in abuse of others; I started to get more graphic--and decided not ..Don't get me started!
My objection to marijuana propaganda is that it is "harmless". It is not. A fact not fully appreciated is that Yes, any substance, including water used to excess is dangerous. Problem is that many people do not have the innate judgement to avoid using any potentially mind altering substance when getting behind the wheel of a car or the helm of a boat.
My personal view is that why make more available other mind altering substances for our youth, and those who are going to abuse it? I fully realize the issues about incarceration, and crime.
The intent of the initial post was to inquire as to how states were handling a potential substance abuse issue, not to start an argument about use of substances which are federally illegal to posses.
