Active member
- Joined
- Nov 21, 2004
- Messages
- 5,934
- Reaction score
- 5
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Meant to be
I've got a Raymarine ST6002 autpilot on the boat. During the season, it started out that it didn't quite hold the course well when it needed to turn to the right and eventually progress to not being able to turn right at all. Engaging the autopilot when things started going wrong would result in a slow drift to the left now it results in a rapid turn left.
I must admit I don't really understand how the pump for the autopilot is designed but I imagine that it is either:
A) two pumps (one to send fluid in either direction) that are electrically controlled or
B) one pump with switching valves or a reversing motor that control the direction of the hydraulic fluid.
ON EDIT: It appears that the standard pump is a reversing single pump.
Give the mode of failure, I don't think this is an electrical/control head failure but imagine that its a pump seal or valve issue. Any insight from those who have fixed or heard of a similar problem?
