Pics uploaded to the album. Every fitting was re-bedded. Bow rail removed and wet balsa core removed and epoxy applied. The forward hatch had leaked, so the balsa core had to be hogged out and replaced with plywood plugs and epoxy, the handrails were sanded and have 5 coats of spar varnish, the rear of the cabin was replaced (used almost all the original hardware), two coats of bottom paint, the gel coat was repaired and two coats of paint on topsides, two coats of paint on the interior, spar varnish on all interior wood surfaces, hogged out the wet balsa core and repaired it where the kicker mount is through-bolted and a new wood mounting plate made, new VHF antennae and a few other minor cosmetic repairs.
I was lucky to have dry, heated space with all the tools etc. . . at my disposal. Not cosmetically perfect, but ready for years of service. I'll be going trolling for kings with the four boys we are adopting as soon as the weekend weather permits.
