qboat
- Joined
- May 9, 2017
- Messages
- 73
- Reaction score
- 4
- C Dory Year
- 1993
- C Dory Model
- 22 Cruiser
- Vessel Name
- Runt
I got Runt a few weeks ago, and this weekend put trim tabs on her. The interior of the transom was pretty soft down at the bottom where the tabs go. Where I installed the top bracket, above the waterline, it was downright punky. I could use some advice. The motor mount bolts are not pulled into the gel coat, so I must have relatively good wood there. The transom passes the "leg" test--that is, there is no flexing when I tilt it up and drape my 220 lbs across the lower unit. So I think it is ok--that is, safe--to use at present. Has anyone opened up a transom on these boats? She is a 1993 22' CDory. Is the transom core balsa, or marine ply, or a combination? Thoughts on preserving the useful life of the transom? I would be grateful for any insights or advice. Happy New Year! Sam
