CAVU
- Joined
- Nov 2, 2003
- Messages
- 665
- Reaction score
- 0
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
- Vessel Name
- CAVU
Dan,
I just finished repairing my tank hold-downs. I would disagree with you about the reason the screws are pulling loose. At least on my boat (2002), the screws are pulled loose by the nylon retaining strap across the top of the tank. When the tank deforms with temp changes, fuel absorption or whatever reason, if the top pushes up on the strap which is firmly atch at the top of the vertical cover board this puts an almost vertical pulling force on the screws. The screws holding the 1x1 cleat to the floor are only held by the thin veneer of fiberglass over the balsa. An expansion of the tank in a horizontal plane would put a sheer force on the screws, in a direction they would be relatively strong. As a side note the tanks don't actually rest against the transom. The rear edge of the tank rests against a SS strap-eye which is screwed to the floor. I do agree the the fix from the factory, at least based on what I have read here, will solve the problem. I think the pressure from the strap theory explains why some people have not had a problem while others have. It just depends on how much you tank deforms against the top strap. Just my $.02 FWIW.
