mikeporterinmd
We like to use a fair amount of 12V power - lights, radio, VHF, etc. And while
doing so, I'd like to have the batteries be charging when 120V is available.
To that end, I plan to install shore power and a 20Amp or so charger.
Right now, it looks like:
CHARLES 93-12205SP-A CHARGER 5000 SERIES 20A/3 BANK or
CHARLES 93-12155SP-A CHARGER 5000 SERIES 15A/3 BANK (more likely of the two)
or
Newmar PT-25
or
STATPOWER TRUE CHARGE 20+ 12V 20 AMP 3 BANK CHARGER
The Statpower and Newmar have remote panel options, but the Charles
chargers are true multi-bank chargers that can output full power to each
bank (hence the likelyhood of a Charles 15Amp model).
They all cost roughly the same - $250 or so, give or take $40.
Anyone use any of these? Any noisy? My old ferro unit buzzed, but it was
below decks, so I couldn't generally hear it.
I am planning to install the unit in the galley, up near the Wallas, with the panel
in the Helm (Blue Sea 3043) and the inlet under the starboard gunnel using
a Hubbell HBL303SS. Yes, I could use the nylon one, but I like SS!
The Blue Sea digital meter panel looks cool, but I can't justify the extra
cost (+$100) unless someone can suggest another reason. We'll use one of
the circuits for the charger, one for outlets, and the extra for whatever
nefarious purposes I can come up with.
I have a good source for most of this, including the wire.
Batteries: will probably go with a group 27 house unless we install
some sort of fridge, then 2x27.
Comments or suggestions?
Mike
or
Newmar PT-25
or
Mike
