Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,767
- Reaction score
- 118
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
In the middle of the night I was thinking about this thread--and agree 100% with TyBoo. I think that you are trying to make the 22 too complex a boat. Don't spend a lot of $$ on a fancy charger--for Dtol with a C Ranger 25--the Xantrex XC series makes a lot of sense. But with your anchoring out--it doesn't. How are you going to charge the batteries when anchored? Only option is some generator--and that is going to cost a bundle--and the noise and fumes which no one likes. The power factor of the XC series may require the larger Honda 2000 (I don't know what the requirement is--so you need to check on that). With our little group 24's on the C Dory 22 we would go 10 days to 2 weeks with no other charging than the outboard as we went from place to place--and some times we would stay at the same anchorage for several days. I did carry a U1 battery (garden tractor) which would start the engine if the others were run all of the way down--and had a small portable digital volt meter to occasionally check the battery voltage. Where would you put a battery in the bow of a 22---especially if you have 100 feet of chain? I think that our 22 had a windlass (appeared to be a bolt pattern which had been filled)--and it was taken off. We never saw a need for one. (Plus you never should try and pull the boat to the anchor with a windlass--use the engine, and the windlass to take up the slack).
I guess one of the negitives of down sizing is that we are used to some of the things we had in larger boats--but I look at it as having less systems to go wrong.
