Well-known member
- Joined
- Oct 27, 2012
- Messages
- 3,764
- Reaction score
- 98
- C Dory Year
- 2008
- C Dory Model
- 22 Cruiser
- Vessel Name
- SoBELLE
thataway":rb6pyag3 said:I have seen my SG200 give unexpected readings. I have found that my batteries were reported to be down to 4% SOC after an hour and a half of running the fridge (towing the boat to the launch). Since the fridge draws about 2.6a when the compressor is running it is not possible to deplete the battery to that state that quickly. Also, since the motor started right up and the electronics all worked, this reading had to be false. This has happened more than once.
Hopefully after some more cycles, the readings will be more correct.
I suspect that shutting off the battery when you are not using the boat is part of the issue--I believe that these type of gauges are meant to be used long term as in day by day cruising--and cycling the battery banks. It may well be that the system has to "learn again. The other issue, is if you are using the house bank to start the engine--that may give some other issues??. I isolate the electronics from the engine start battery. I learned that lesson many years ago, when I blew the diodes on a very expensive Kenyon wind speed and relative angle system in the early 1970's--voltage drops and spikes during engine start need to be filtered out. Modern electronics are better 40 some years later, but I occasionally still hear complaints on places like THT where someone has electronics problems related to using them on the engine start battery.
What does the SG 200 voltage and amps used, and Health of battery show you after this very brief run?
I would ask the question of Balmar engineers and Rob Collins to see what they say. I leave my house battery bank on and the Norco "Genius" charger running all of the time. (but I don't have one of the SG 200--maybe I need to compare it with the system I have. That gets complicated with two shunts on the same battery bank.).
Same thing happened again today. The boat was plugged in and charged up. Before we left the house, the SOC was 93%. When we got to the ramp about 1.5 hours later, the SG200 said the SOC was 1%. The only thing during the ride was the SG200 itself, a couple of USB ports (but nothing plugged into them), and the motor tilt was run once up and once down for the trailering. Once the boat was running, the batt SOC was 100% after 20 minutes. When we arrived home (which is actually longer than the trip there with the same electrical loads) the SOC was 94%. Since the engine started fine and all the electronics worked, clearly the battery was not at 1% charge when we launched the boat.
