Tug
- Joined
- Jun 22, 2007
- Messages
- 996
- Reaction score
- 0
- C Dory Year
- 1985
- C Dory Model
- 22 Angler
- Hull Identification Number
- DOR22241H585
- Vessel Name
- Drifter
Did the Battery Switch installation this afternoon..
** Battery # 1 = starting battery
** Battery # 2 = house battery
** ran a cable from negative post battery # 1 to negative post battery # 2
** ran a cable from positive post battery # 1 to # 1 post on the switch
** ran a cable from positive post battery # 2 to # 2 post on the switch
** ran the positive wire from the motor to the common post on the switch
** ran the negative wire from the motor to the negative post battery # 1
** ran ( attached ) the positive wire from the ( distribution panel ) house circuit breaker to the common post on the switch...previously was attached to the positive post on the battery with the motor ( starting ) wire
** ran ( attached ) the negative wire from the ( distribution panel ) house circuit breaker to the negative post on battery # 1..previously was attached to the negative post on the battery with the motor starting wire.
This is what i did so far as to check this wiring :
With the switch in the off position nothing works.
With the switch in position # 1...@ # 2 i can light up and run all the on-off toggle switches on my distribution panel. Is is suppose to work on Switch position # 1 @ # 2
I have not tried starting the motor yet...need to get some gas first. lol
Does this sound like i wired it correctly so far...Thanks Tug
