Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 0
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Sea Wolf":1xrpq2nj said:Since..so much seems to ride on Les's past stated preference for the BayStar system that is not presently clear, I suggest you write him a PM and ask that he comment on this thread.
I thought about that, but I just knew I had the information somewhere -- I only had to find it :wink: Anyway, here we go, fresh from the year 2002 :wink
The Teleflex BayStar system is the "factory standard" hydraulic system from C-Dory on the CD22s. It's the model that was installed on C-Salt and it worked superbly even when equipped with the Raymarine ST5000+ autopilot.
The BayStar system uses 3/8" hydraulic tubing rather than the large hydraulic hoses that the SeaStar system uses and has a molded helm unit rather than aluminum. They can do this because the BayStar system does not have to generate the amount of PSI that the SeaStar system does (which is what the 150hp limit is about). Those big hoses on the SeaStar system are spendy (and don't come with the helm kit) and come in one foot increments, the ends are swaged on. The 3/8" tubing the BayStar utilizes comes in a roll with the steering kit and is easy to cut with a tube cutter; it uses compression fittings rather than swaged fittings.
And the part I like best (other than the much lower price) ... the BayStar uses a fixed cylinder, moving ram system rather that the fixed ram and moving cylinder of the SeaStar. That means the hydraulic tubes going to the cylinder on the outboard do not have to move in the motorwell. The BayStar system uses the same drag-link that the cable steering system does so it's easy to hook up at the motor end. In fact, the whole installation is pretty easy.
The BayStar cylinder is universal for all outboards since it doesn't connect directly to the engine; it's held by a rod through the tilt tube but doesn't connect to the outboard's steering arm. Instead, as mentioned above, it uses the standard drag link that came with the engine.
I love hydraulic steering so I'm not an objective person to ask about whether or not it's worth it. If I had a CD16 with a Honda BF50 it would have BayStar steering; I like it that much.
Plus it makes adding a good autopilot really easy.
Les
Now, everyone may not agree with the information above (who knows, maybe I wouldn't either once I had laid hands on both systems); but it's what had stuck in the back of my mind that I was trying to remember/understand. I'm still completely open to either system, and will be until I purchase one or the other. In fact, my usual tendency is to go for the heavier-duty setup, all else being equal.
