C-Nile
- Joined
- May 9, 2008
- Messages
- 638
- Reaction score
- 0
- C Dory Year
- 2012
- Vessel Name
- Betty Ann
We had our boat in valet storage for the past seven seasons, but we eventually felt unduly constrained, having to vacate the dock within one hour of launch to become a transient at a local marina. The season was May 1 through October 15, which was short for our type of boat. So we moved to a wet slip in Mystic, CT, and lengthened our season by approximately 6 weeks. This means we had to undercoat our hull with ablative paint.
We had installed shore power with three GFI outlets, a Smart-plug and outlet, power distribution panel, and an onboard battery charger.
I got tired of moving a portable A/C in and out of the side window, so we had installed a Dometic Durasea roof-top A/C unit. We don’t think it spoils the look of the boat, and it does not appear to have had an appreciable effect on the boat’s stability. The Dometic was the smallest rooftop A/C unit we could find; why don’t they make smaller units? We had considered other options, but we did not want to punch a hole through the bottom of the boat, and we did not want to take up valuable space inside the cabin with ducts and associated equipment. Our boat is now uncluttered. The rooftop A/C does prevent the radar from seeing directly behind us, but we can see the flanks of the boat just fine. In the future, we may elect to raise the radar dome above the A/C unit, but then again, we are only going to venture away from our slip 4 or 5 times, and only in good travel conditions during the day. We’ll see.
We removed our Tohatsu kicker. We have SeaTow in our area, and we have abandoned our gunkholing aspirations. So in the event of a major engine failure, we will call them; they are fantastic. The kicker has given us a lot of grief. The carburetor has been fouled by ethanol for years. I spoke with a mechanic about this, and he recommended using no-ethanol gasoline that you buy in a can. Where was he with this sage advice 9 years ago? But it is costly to maintain an extra engine we may never again use, and we are glad to rid ourselves of it.
We removed our Wallas stove; we didn’t like the diesel smell. So we installed a utensil tray underneath the countertop, and an 18” by 22” cutting board on top to cover the hole, and lift up to gain access to the utensil tray. We have gone all electric — appliances, and a Caframo heater.
We don’t want to move the dinette rear seat cushion at night to extend the berth, so we made a spare cushion out of 1/2” plywood, 4” high density foam and Sunbrella fabric. It fits like a glove, and stays in place most of the time except while underway.
Getting back to the removal of the kicker—it really helped in leveling the trim of the boat. I discovered by accident late last year that with no water in the bow tank and no anchor or rode, it was very hard to trim the boat to optimal levels even with full engine tilt and trim tabs. I have a hunch that in head seas or a heavy chop, it will be easier to keep the bow down and maintain proper trim now that the kicker has been removed. Now I see why people use Permatrim.
This is our 9th season with the Betty Ann (production hull 0001). She looks nearly as new as the day we bought her, but alas, she is going to take a beating from the sun now that she is no longer in a boat valet storage facility.
