C-Wolfe
Active member
- Joined
- Sep 16, 2020
- Messages
- 408
- Reaction score
- 29
- Location
- Anchorage
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Callisto
Starting the starboard engine as been getting more finicky the last few months, with what look to me like a neutral switch issue. When I turn the key nothing happen, wiggling the shift/throttle handle seem to be helping in getting the starter to finally engage, unless its just luck. I opened up the remote control box a couple days ago and there is no neutral switch inside, next I should be look at the engine and locate the neutral switch but its snowing outside so I'd rather wait for a better day for it.
With the control box detach from the bracket and cover remove, I was not able to duplicate the issue, the starter engaged every time, even once I shifted in forward gear and the starter engage anyway. Is it possible that there is no neutral switch? The control box was detach from its bracket but I don't see that making a difference. Could it need adjustment at the shift cable? I'm not quite sure how to do that yet. The next suspect might be the starter solenoid but somehow I don't feel that is the problem.
I'm just curious to know if anyone had that issue and can provide advise on the troubleshooting.
Engine is a 2007 Honda BF50 carbureted. I'll post a picture of the control soon.
Thanks for any advice.
