timflan
- Joined
- May 16, 2006
- Messages
- 550
- Reaction score
- 7
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Vessel Name
- Two Lucky Fish +1
The Rule-Mate 1100 Automatic Bilge Pump just inside the cabin will run when there's water present, or when I turn it on. And it pumps water, which comes out the side of the boat. So far, so good.
Except that after about 30 seconds, water stops coming out the side of the boat. The pump is still pumping, but no water is moving.
Turn it off, turn it back on, and it works again. For about 30 seconds.
I was emptying/refilling the water tank today, relying on the bilge pump to carry the last water in the tank away. And since I had the hose rigged up, I hosed out the cockpit floor today. Bilge pump running constantly, of course. Except...the water level wasn't going down. That's when I discovered the pattern I described above. Had a lot of water to drain, so many chances to test it out.
It just WILL NOT pump consistently. It's as if it's got some sort of priming/vacuum seal/vapor lock sort of issue going on, even though the pump is submerged enough that water's draining out of that little sump and getting into the cabin.
Has it gone bad?
Tim
Has it gone bad?
Tim
