20dauntless
- Joined
- Jan 23, 2008
- Messages
- 879
- Reaction score
- 0
- C Dory Year
- 2008
- C Dory Model
- 22 Cruiser
- Vessel Name
- Retriever and Nordic Tug 37
Chuckpacific":3kbtxue7 said:In my current boat I have a Webasto diesel heater and a propane stove. Granted, it is a different boat, different setup but I now realize what I was missing. I can easily get the inside temperature up to 80+ degrees should I want and I can boil water in 3-4 minutes.
Same here, except my heater is Espar not Webasto. Not having to wait 15+ minutes for the Wallas to get hot to cook on is great. And having near-instant heat ducted throughout the boat is much more effective.
ALL of these heaters require maintenance. When they start smoking on startup/shutdown they're accumulating soot in the combustion chamber. Eventually they'll be so dirty they won't light and they'll need to be disassembled and cleaned. The Wallas cooktop is actually pretty easy to disassemble and clean. I had to do it several times and it only takes ~45 minutes. You need a bottom mat and ring, wire brush, and vacuum. Also carry a spare glow plug.
My Espar hasn't been trouble free. I've replaced a glow plug and two flame sensors, although the second flame sensor replacement was only a week after the first and was probably just an unfortunate fluke.
I think many of these heaters have a problem if they run on too low a setting or cycle frequently. Both situations cause soot to build up more rapidly. It's probably best to run the Wallas on high all the time and open a window if things get too hot inside. Many of the furnaces cycle on and off, which can be tough on batteries since start up draw is high. And in my case, with an oversized (Espar D8LC) furnace on the NT, the furnace normally only runs for less 10 minutes at a time once the cabin warms up. The frequent start-stop cycles create soot.
