Boat Lift Bunk Input
SEdowneast
Apr 2, 2025
14
2
Location
Lake Murray, SC
23 Venture
Hello fellow C Brats. I was looking for some input from those who keep their C Dory's on a boat lift. I keep my Venture 23 on a lift with two bunks where the lumber is set on flat edge with a 7-8 degree angle that has been ripped into the lumber to accommodate the increasing dead rise from stern to bow. On top of that is a thin rubber strip and carpet. What I've found is that the boat does not want to sit flat on parallel bunks. Generally the stern lifts up as the boat rocks forward. I believe this because the hull slopes down from stern to bow and this was based on the measurements of the trailer bunks with the boat on it. The boat sits flat on the trailer bunks for 9 feet. I am thinking that this may only be the case on the Venture's hull, not the other Cruisers because of the different hull design.
I have been able to achieve a level hull sitting on the bunks when I pinched in the forward bunk brackets a few inches each side. However, I believe there was too much pressure where the pinching was, as the bunk carpet was getting very compressed in that area and I had some rubber transfer that left marks as well. The marks came off easily, but to me I felt that was something I should address.
My plan to solve this was to raise the front lift bunks to match the trailer set up. However, before I did anything, I thought I might reach out to see if anyone has run across this issue on a Venture or even a Cruiser and how it was handled. Also, for those that have boats on lifts, I would be curious how well the hull contacts the boat lift bunks.
Thanks so much!!
Bobby
