Milehog":2mwzyh3a said:
Sea Wolf, good common sense tip, thanks.
Now, I hope this isn't too off topic. What are good ways to fill unused holes and penetrations? I'll have some below the waterline after an upcoming project.
I used the search feature but didn't find anything definitive.
Bob Austin (Thataway) will be able to give you a more professional answer on this, but here's what I would do:*
Make sure the holes are cleaned out well. Any exposed balsa core must be removed with the nail in the drill trick with the nail head bent over into a "cleaner-outer" or similar working tool.
You may or may not be able to get to the inside of the hull. If you can, it can be roughed up and taken down to expose the resin, then covered over with a few or several layers of glass cloth and polyester resin. This is the strongest and best way to do it, but smaller holes may not need the extra glass, and you may not have access to the inside, of course.
Next, all the void must be replaced with polyester or epoxy filler.
I'd use Marinetex and simply try to match the hull color with a universal fiberglass tinting kit, finding the color match through testing initially.
If the hole is larger and you can't fill the backside with layers of fiberglass first, I'd then first start out the hole repair by using a suitably tough and strong metal or fiberglass flat piece (a piece of sail batten would be great) inserted into the hole and epoxied into place to backstop the fill.
Then I'd fill the hole level, keeping in mind that the filler can shrink and a second application may be required to get the fill level. Once it hardens, it can be carefully sanded down, polished, and waxed. Marinetex is tough stuff, unless the hole is large or stressed, it should be adequate to just fill the hole with it, especially considering the plug will be expanded outward around the hole to fill the space left by the balsa core.
However, if the hole(s) are somewhere the appearance is of paramount importance or the gel coat cannot be matched by tinting, the hole must be filled shallow to allow for the addition of gel coat to match the original.
The C-Dory factory offers small bottles of gel coat to match their colors. I'm not sure how far back in time they go with this, some earlier boat colors may not be available.
There is also a company that offers gel coat repair kits to match a wide variety of boats, models, and years:
LINK Click on Gel Coat Products, then C-Dory.
The procedure for doing the gel coat repair should be available here on our site:
LINK
* There are sometimes polyester to epoxy bonding issues involved here, but I've never experienced them with Marinetex to polyester resin hull combnations.
