Boat + Tralier max lateral tilt
Joe
It has a pretty good pitch to it. You can see the traction rungs cast into the concrete sidewalk. But still even with the lateral slope I think it is doable.
Hi ferret, Tom is right on trucks with manual hubs you can use low range to the rear with the front hubs free. Without manual hubs there is usually a way to defeat/overide the engagement of the front axle. Not sure what you have but on my last truck(96 Tahoe) there was an actuator on the front dif. - electric solenoid that turned like a screw to mesh the gears. If yours has something like this - look for a fuse or crawl under and pull the plug.
The only thing you have to concider is that in 4L you are transfering a lot more torque to one drive shaft then it was designed to handle. Be very gentle on the gas and check your U joints. Not trying to scare you but if you did blow a U joint backing up the hill - you would be stuck with your foot on the brake until you could coast to a level spot. You would be immobile and putting it in park would do nothing as both your front and rear wheels will now be freewheeling. :shock:
Sorry but I had to add that disclaimer :!:
You might be OK in 2H - but pushing/pulling a heavy trailer up a steep hill in too high a gear puts strain on the clutch or A/T.
Lots of Bratts here cheering for you - if we all got together we could carry your boat in your driveway!
Good luck, Rob
