Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,808
- Reaction score
- 152
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
n the cabin, I changed all my cabin lights to LED with both white and red options. Both work at the dock, but the red lights in the cabin are WAY TOO BRITE to use for navigation. I found that as an option to no light, I use a headlamp with a red LED and put it on face backwards, (still bright) so I put a red bandana over it. Gives just enough light to give some peripheral vision. Also, All the lights on all the nav gear are turned down to minimum. Some don't go dark enough so they get a cover of some sort.
There are several ways to dim LED's. some of my fixtures have a "bright and dim" switch on them--basically a resister in series with the LED on one of the legs to the LED.
How to determine the correct resister for LED lights.
You can put several of the lights in series, and you can use commercial dimmers.
I just buy the cheap LED's in bundles of 50 or 100. Put them in using #22 wire (solder connections). I have red LED in cabin fwd, aft, head over dinette and over galley, plus in the bunk. Onside on the side boxes and from above the door covering the entire cockpit in red light...Cheap and easy to do. Drill holes in Starboard, or wood (teak) the diameter of the light, and hold in place from the back with a dab of sealant--silicone works fine in these cases. You can "aim" these little LED's.
From Adorama (camera store) you can get a 24" x 21" red gel filter for $7. This can be put over chart ;plotters or lights to dim them further.
Lots of ways to "dim" a C Dory...
