Well-known member
- Joined
- Oct 27, 2012
- Messages
- 3,714
- Reaction score
- 59
- C Dory Year
- 2008
- C Dory Model
- 22 Cruiser
- Vessel Name
- SoBELLE
Barry Rietz":24usuvol said:Robert & Karen, If your frustration level begins to overwhelm your patience, you might consider using a "one piece cast stainless 316L pad eye" like the one shown below. This would allow you to use bolts, (with nuts on the outside of hull), to conveniently tighten securely. Use of "medium" Locktite on the "nuts" will allow for future tightening should they require it.
https://www.marinedepotdirect.com/oblon ... zEQAvD_BwE
Still need a backing plate and have to get a wrench on the inside bolt head when you tighten the outside nut. So I'm not seeing much of an advantage.
