Bring Unconscious MOB Aboard
True North
Jul 30, 2026
12
2
Location
Blaine
I have started this thread after asking Thataway a question about how he used his davit to get an MOB back onboard. I hope other C-Dorians will share what they do.
The conversation so far:
MY QUESTION
Bob, I'm researching how to get an unconscious MOB back aboard a C-Dory 25' and was struck by your stating that you practiced with your dinghy hoist. My husband and his wet clothes would weigh about 225 lbs if he were the MOB. If unconscious, he would need to be winched aboard somehow and a dinghy davit seems to be the only way to do this.
So... many questions: Where was the base mounted on the boat How much did the boat heel when you were lifting and swinging aboard the MOB? Can the MOB be swung into the cockpit? Could you have attached a "net" to the davit arm so that you could lift the MOB horizontally (to prevent circum rescue collapse)?
ROBHWA's RESPONSE
Fellow C-Dorians; Bringing a "dead-weight" (i.e. can't help in their rescue) heavier person over a ledge is a common problem practiced and unfortunately sometimes done in mountaineering rescue. I had the opportunity many years ago to participate in such a rescue on Mt Rainier. Approaching it with a fiberglass "ledge" on a C-Dory poses a similar problem to bringing the person over the edge of the crevasse. I also recently helped pull a 170 lb halibut into a boat, not a C-Dory but with similar relatively low gunwales. One person tried but couldn't lift into the boat themselves. 2 people couldn't easily either. I was surprised that it took three people to wrest it over the side. Basically, you're going to need "mechanical advantage" with a pulley system and a firm place to anchor it. I've practiced doing this with 250 lb people over the edge of crevasses using a 3:1 mechanical advantage "Z-system". Not easy but doable if you place a pack at the edge of the crevasse so the rope doesn't dig in. You are able to use your legs, which might not be easy on the boat. I wonder if such a system might be adapted to rescue on a C-Dory? The crux of the problem is probably bringing the person over the gunwales of the boat. Has anyone tried this in real life?
Thanks for the link! That's an impressive product. It's similar to the Jason's Cradsle MOB system in that they both keep the MOB horizontal and then roll him aboard (https://www.survivalsystemsinternational.com/middle-east/jasons-cradle/).
Howcould it be adapted for use on the C-Dory 25' itself? There doesn't seem room on the side deck to roll the MOB aboard in that location. While I think it could possibly be suspended from the davit and lowered into the water, I can't think where the MOB could then be rolled aboard.
We boat in the PNW, where Cold Water Shock can be triggered by sudden immersion. As my husband and I boat as a couple, if he goes overboard, I will need to recover him alone. I do not discount the use of a Mayday call, but I will need to get him out of the water and horizontal immediately, if I possibly can.
I do not have the upper body strength to roll an MOB aboard even on a boat that facilitates that manoeuvre. Hence my question about the use of a davit, and where it could be positioned --- and also whether it could even lift 225 lbs.
