Well-known member
- Joined
- Oct 30, 2006
- Messages
- 12,662
- Reaction score
- 28
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- Brat # 2202
- Vessel Name
- Sleepy-C
OK, so now I have addressed the bunk board issue, and I am moving on. Next layer up is either carpet or some sort of plastic slide or glide type material. I have gone back through the entire "Trailer and Towing" section and this is not really addressed.
As I see it: (Please add to these as you see them.)
Carpet Pro's: Does not hold water against the hull. Has more friction, so less movement when towing. Maybe less wear on the gel coat.
Carpet Con's: Might hold grit or dirt, wearing on the hull more. May need replacement more often.
Slick Pro's: Less frequent replacement needed. Easy slide on and off. Easier application to the bunk boards.
Slick Con's: More expensive than carpet. More slick than the carpet, so more motion when towing. Questionable increased wear on the gel coat, due to harder surface.
I am interested in hearing other views, suggestions, opinions and comments, particularly before I start with the covering.
Thanks all, and good night,
SleepyC
SleepyC
