Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,911
- Reaction score
- 261
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
I made it clear at the first of any thread dealing with this boat I knew what I was getting into. But what has been the big surprise, is that the failures were caused by lack of proper bulding techniques. Yes, the boat was used hard (but not many hours--only 121 hours on the engine). Yes, the boat was left out with the cockpit uncovered in New York for at least two winters. (I believe it was shrink wrapped at least two winters).
To answer a couple of questions:
Best day asked about the screws on the transducer: They were put in with silicone. Silicone has no business being used under the water line.
The trim tabs were bedding with something else, and there was zero water intrustion in where these screws were.
I feel that it is proper to screw a "Starboard" piece (with come hatch cuts so that 5200 will stick) to the transom to allow the transducer screws to not be into the core, or to allow the screws to be moved. The Starboard screws will be into epoxy, where core material is replaced, so no water can get into the core--this is NOT a factory issue.
Journey On asks if there is anything which makes me think that hull #30 is unique in its problems--and my response is NO. I suspect that all of the boats built at this time had these problems. How is the load of the motor transfered to the hull?--With the plywood core (non marine grade) only comming to inside of the edge of the splash well, there is relitatively thin glass on each side of the wood which transfers the load. This glass can flex under some circumstances--the other "bracing" is where the transom ties into the corner of the splash well. Unfortunately this lacks sufficient, if any, glass, and is the reason that a number of the boats have cracks there (At first I thought that this, and the cracks in the foreward cockpit floor were just thick gel coat, and a sharp radius. Unfortunately this is not the case. The load of transom flexion (foreward pressure on the upper part of the transom) is taken to the corners of the splash well, as well as the glass only, and it will crack because of lack of reinforcement with glass. I don't think you are going to see motors fall off. But with time, this cracking may extend and become a major issue.
Many boats have an issue with the hull to deck joint at the transom--Grady Whites had this for some time (resolved in the 1990s). There should be glass tying the molds of the spash well (deck) and transom (hull). In this boat, was no glass over this area, and a crack developed (see the photos). This has now been fixed. Biaxial glass (multiple layers, with epoxy have filled the void at the top of the transom and sealed the core at the top. There has been glass to spread the load to the splash well both inside and outside of this structure, after the filler was ground away.
I appologize for not having interacted with Mr. Hoffman. I get the NMMA publication and didn't notice C Dory certification. The current web site does not show C Dory as certified (Please correct me if it is certified and cite when). I complained in June 2006 that there were a number of issues on the Tom Cat 255 which were not to ABYC standards. I was told that NMMA certification was expected in July 2006. I checked again several times and it was not certified by the end of 2006. Mr. Hoffman, I certainly hope I do not always have to wear a life jacket when boating!
To DrJohn: I would not call the boat a "damaged hull and neglected". If you look at the outside is is very nice looking. The hull took minimal compounding to bring to like new condition. The eyebrow and top will take a little more work, and reflects not being waxed or protected regularly. I made an assumption that the CD 25 was built to at least the standards which my 1992 CD 22 were built to. (probably a poor assumption) I have seen a number of CD 22 which have been far more abused and which have no problems. The problems were due to manufacturer defects. I discussed this boat with Bret Reynolds and have commented on his response in another thread.
The defects are not those of developement--they are just common boat building knowlege: Transom cores need to transmit the load to the sides of the boat, you should not attempt to bond hull to deck joints with filler and no glass (especially when tying together sides of a tansom) You must seal cores, you cannot put screws into cores which will have water on them, you must seal limber holes with epoxy. (Bostik and gel coat don't work) You can not leave voids in either balsa core or plywood core.
We will see what C Dory's final response is when we submit all photos after the work is done. The hull warantee is 5 years, but non transferable. After finding what I have, I have concerns about the boats which have aluminum tanks. I fear that these tanks may sit in water (unless the boat is kept covered).
Questions I have today are: are the CD 25 Transoms marine grade plywood, encapsulated in Epoxy, or totally encapsulated in glass, with no voids, and are all holes in the wooden transom core sealed with EPOXY?
Does the wood core go properly from side to side on the transom?
Is there a void in the bottom balsa core at the aft end of the bottom?
What is the laminate schedule of the cockpit floor?
Are any screws put into the inner layer of the boat's bottom balsa core?
Are all holes in any balsa cored area routed back and sealed with epoxy?
Are all electrical, plumbing and fuel specs up to ABYC standards?
Are all aluminum tanks set on plastic strips, with 5200, so that they will not sit in bilge water?
My next post will deal with further steps in the repair and what further we found.
