pcg
- Joined
- Aug 31, 2018
- Messages
- 470
- Reaction score
- 15
- C Dory Year
- 1999
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- DOR22866J999
The wipers on my '99 Cruiser are manual. Parts are corroded and need to go, so as part of my restoration I'm installing a powered pantograph system with motors mounted above the windows as found on the newer 22' Cruisers. I'm sharing part numbers and costs and also have some questions. I got the part numbers from the C-Dory factory (thank you Sean) and prices from the supplier, AM Equipment, https://www.amequipment.com/. Total for both sides (need two of each below) comes to $690.68.
Motor, 50mm shaft, 85 deg sweep, Part No. 212-2201 $172.99
Harness for above motor, Part No. 310-1076 $9.27
12” Blade, Part No. 302-1120 $13.88
Wiper arm kit (Part No. 114-1132) consisting of the following:
- 13”arm with ½” drive, Part No. 352-0530 $87.15
- 3” Pantographic adapter for above motor, Part No. 305-1015 $15.77
Knob Switch (2 speed, wash, use with one motor), Part No. 311-1022 $38.78
So now the questions...
1) The AM Equipment website implies that each wiper needs its own switch. Is this correct?
2) If so, has anyone used an aftermarket controller and switch to control both wipers with one switch and also have an intermittent function?
such as the Schmitt controller:
https://www.hodgesmarine.com/ong32010-o ... EREALw_wcB
or the Marinco controller:
https://www.westmarine.com/marinco-dual ... XaEALw_wcB
Pros? Cons?
3) The AM switch, as well as the aftermarket controllers above, has a "wash" function. Do the new C-Dorys have a window washer function? Useful? Where is the reservoir mounted?
Thank you!
Pros? Cons?
Thank you!
