Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,946
- Reaction score
- 291
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
This is not the place to debate DC vs AC power as a danger, but AC is considerably more dangerous for multiple reasons from a medical standpoint.
I assume that Rich has actually measured the current draw of his 200 watt inverter powering the 810 lumen equivalent 60 watt light bulb. If one was to use 12 volt LED's to give 800 lumens, the current draw would be just under 1 amp at 12 volts. Thus he is using twice the current necessary. (The 2 amps Rich cited also fit with the efficiency loss of an inverter, and converting AC to DC to power this size LED.) The footprint of the 12 volt LED package would be a fraction of the size of an inverter, fixture, equivalent size 110 volt bulb. I suggest that Rich look into the use of 12 volt LED's to give the indirect light he requires.
If indirect light were a desired feature for other C Brats, it would be very easy to design a light to do this. For example, a 10W 3000-3300K 800-Lumen Warm White Light LED Emitter(9-12V,850mA ) is $6.50 (less if bought in bulk) The fixture could be made to be less than a 2" cube. However, each of our boats is different, and the place we want the unit put will also be different.
