Avidmagnum12
Active member
- Joined
- Mar 23, 2013
- Messages
- 759
- Reaction score
- 57
- C Dory Year
- 2011
- C Dory Model
- 25 Cruiser
- Vessel Name
- C-Otter
Other C-Dory owners and other boaters often ask what I tow my 25 with. When I tell them I tow with a F-150 they generally are quite surprised. I tell them that you can easily tow a 25 long distances with a F-150 but NOT every F-150. Saying 150 is like saying airplane. An airplane can be a cub or a jet or something in between. Some F-150's can tow well over 11,000 lbs with the correct engine and gearing. Some older ones way less than 5,000 lbs.
So when someone says that they were scared or nervous towing with a 150 I'd sure like to know what the towing capacity, wheel base, gearing, engine, tow package or lack of one and the other weights that apply out of the owners manual or sticker. The truck they were using may not have been up to the task.
I tow with a 2012 F-150 with the 6 cylinder twin turbos 3.5 liter eco boost engine, 9,600 lb towing capacity. Towing package with extra cooling. Normal transmission temp about 195 degrees. The highest I've seen is 205 on a real hot day. I'm usually towing about 8,000 or so lbs. Sometimes more. When I first got the C-Otter it was scaled with a full load. All the weights came out well within Ford factory specifications.
I do highly recommend EOH brakes although I towed over 4,000 miles with surge brakes with no problems. There were a couple long wet ramps that I passed by. Towing from Florida to Lake Superior and back every year puts on more than a few miles on the rig including over 400 today.
I guess all I'm trying to say is that it can be done safely with some F-150s but not all.
If you prefer a bigger heaver truck...You can't go wrong.
Enough...heading home to Florida after the great Meet in the Middle gathering. Had a great time. Also got to help launch a 25 named Dragonfly that was towed in on a NEW F-150. Nice ride Joyce and Wolfgang!
