What a MESS... We discovered it several months ago... that the shaft seal on our BayStar helm had worn out and was leaking...and had oil soaked my side of the cushions in the V berth.....
So I went to West Marine and ordered a new set of seals...but the first set were for the late model helms and mine (2003) was the "old" style and they did not interchange...... so they got a set of seals for my style helm and it went together just fine.... but leaks.... not a little but almost runs out ....I think it is coming from not the shaft part of the seal but from around the edge of the white plastic seal holder... there is a small O ring between the housing and the seal holder but that does not appear to be doing much....
Anyone else have this problem ? I wonder if I should just buy a whole new helm unit...I sure don't want this to happen when I am on the water....
Joel
SEA3PO
Camarillo Ca.
Joel
SEA3PO
Camarillo Ca.
