theleverbeef
- Joined
- May 7, 2012
- Messages
- 34
- Reaction score
- 0
- C Dory Year
- 1988
- C Dory Model
- 22 Cruiser
Thanks for the tip!
theleverbeef":opq9qbkm said:Thanks for the tip!
adoryable":zwfbs2oj said:Does anyone else have this problem? I am experiencing engine revving on my 16 foot Angler (1989) with a new 50 HP Honda. The engine and prop were professionally installed by a dealer in Portland OR (who sells C-Dorys) and the plate is at the correct level in relation to the bottom of the boat. The prop has been checked and is not slipping. The motor is mounted at the lowest point.
The motor revs when running at 4500 RPMS or above (17 knots or more) when moving with following seas, and occasionally when going into modest swells. The revving is worse when I have a second or third passenger onboard. I have tried adding a after market plate which helped somewhat.
I also sucked air (and revved up) when making turns, but the add on plate helped that situation considerably. Could this just be a fact of life for this flat hull design?
PROPELLER CAVITATION
Cavitation if the formation of air bubbles on the propeller. Cavitaion usually occurs as a result of damage and you'll feel it in the form of vibrations.
Cavitation is bad for three reasons. First it can physically damage the propeller. Secondly, it causes those vibrations which makes your ride less comfortable. Thirdly it reduces bite, which reduces efficiency.
PROPELLER VENTILATION
Ventilation, on the other hand, is the propeller sucking in air. This may happen because you have the engine trimmed up too high. It can occur because you're jumping waves and the back of the boat is actually coming up near the surface of the water, or perhaps you have a really sharp turn and as the boat leans your propeller is too close to the surface.
Ventilation is also bad mostly because it can cause a radical reduction in thrust and also it can cause your engine to over-rev.
CAVITATION AND VENTILATION HOW CAN YOU TELL THE DIFFERENCE?
If you can feel vibration and your propeller has visible pitting, you have cavitation and you probably need professional help. If, however, your engine is over-revving you have a ventilation issue and this is usually something you can fix yourself.
