Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,086
- Reaction score
- 61
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
There have been a few other threads on this topic, but I'm starting a new one to bring it up to date. The hatches in the aft cockpit of the 25, at least in my 2009, are poor in design and do little to keep rain or wash water out of the bilge. After attempting to fix a leak underneath my aft cabin bulkhead that was letting water from the bilge into the cabin, I decided I would also replace the aft cockpit hatches. (Hoping the leak repair works this time.) I am going with the hatch recommended by Dr. Bob in an earlier thread:
Googling, I found the hatch is currently available for around $170 at several providers. However, I got lucky, and was able to bid two new ones at $120 each on ebay. They should be here sometime in the next couple of days, and I'll provide photos and descriptions here as I install them. The old hatches have a seal in the bottom frame, and then the hatch (wood/fiberglass/gelcoat) closes down on top of that. However, the seals do not appear to be sealing anymore, and any water that flows into this crevice will enter the bilge when you open the hatch, if not before! For those that have already installed these newer hatches, I'm open to any advice before I begin work installing them. I did purchase some #8 x 3/4" ss screws already. And I have plenty of 4000 sealant leftover from earlier projects. ColbyInnovative Product Solutions Boat Hatch 520-625 | Polar White 12 x 26 This is about $120. This has no hinges, and uses a wedge structure on the back to give the pressure.
