I fish for salmon and steelhead solo often and usually my boat (not yet a CD) is anchored and back-bouncing a weighted dropper line (about 3-5 ft. long, depending on 11 -- 60 ft. of water) rigged to a 3 way swivel or slider, with the spoon, brined herring, spinner or Kwikfish (+sardine wrap) trailing on a 3-6 ft. leader behind that in the Columbia river. It is very easy once set up, lazy man's fishin'.... But when we troll here on the lower Columbia, it is with the same gear. This allows us to follow the contours of the river bottom, keeping lures/baits right in the fish zone, a few ft. within the varying bottom. This requires constant mending of line. You let out until you feel it hit sand, then reel up a skosh, and you're there. I could not do this from the helm inside a cabin. This is very different from fishing the salt water at a fixed depth with divers or downriggers where snagging the bottom is not very likely and you just putt along. Trolling as I do requires the fisher to hold the rod and constantly adjust the reel. You have to be in the cockpit in the stern, or you're not really fishing. THEREFORE: It seems I'm best off looking for my new C Dory equipped with a main engine and a high thrust kicker with a tiller. On the other hand, fishing the Pacific, and if main motor fails, a kicker will steer the boat but not likely have enough umph to bring the boat home across the Columbia River bar (treacherous currents). Here is where a 40 or 50 horse backup/twin would prevail and get me home..... hmmmm what to do? I lean towards the first option.
C.W.
