CENTER WINDOW LOCKING SYSTEM
i have had a continuing problem with my center window's locking system. it's the standard shaft that extends and then a screw type device tightens and thus holds the window open. the problem is during a slight chop the screw system will not hold the window open and it will slowly close. doesn't matter how hard i crank the screw thingy, just doesn't hold. i've thought about drilling a hole in the metal shaft and inserting a pin when the window is in the open position but probably think one of you guys have experienced this and have came up with something better.
so would be interested in hearing solutions.
pat
Mine did the same thing, I don't think they are made to hold it open while pounding through the chop. I always just cracked a side window instead if it was rough.
Sark
hey mike and sark,
not sure about the red ribbon, probably be more inclined to hang a cold dos equis. so, didn't know if there was something easier than drilling a hole, but if that's what it takes. tired of that window closing, during the hot season need the window open to cool the interior.
thanks
pat
patrick and linda":12itv79p said:
milehog,
interesting name!
thanks for the referral, somehow missed that string of posts.
pat
Milehog is slang for a railroader that works a lot. We get paid by the mile in through freight service.
The first internet forum I joined is a Harley Davidson riders site and I thought the (Mile) hog a.k.a. Harley pun was fitting. I just carried that username here.
I could swear that I've seen some newer Dorys with the black nylon style adjuster (similar to the ones on the forward hatch) instead of the stainless arm with a butterfly tightener.
In addition to the problems mentioned above, the butterfly, when tight, is turned so it tears the rubber window seal when the window bangs shut. And it's damn near impossible to tighten sufficiently in any conditions. Anyone out there have a different one, or am I making things up?
bmc
Like some other Brat's I removed the offending support arm and drilled it to hold a pin - in fact, I drilled several holes (one inch apart)so the window can be held open in various amounts. When not in use the pin is clipped to the bracket hinge so it doesn't get lost.
I haven't found that the stresses on the hinge (wave chop, etc) were enough to hurt the hinge - but it was just enough to cause the original friction fitting to come loose letting the window constantly slide closed.
It was a perfect, easy fix. The only challenge was holding the round stock (window arm) in position on the drill press and getting the holes properly positioned. ...oh yea, then I also learned how Hard stainless steel is! (Use a good drill bit and go slowly.).
Best,
Casey
