Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,108
- Reaction score
- 78
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
This isn't really about replacing the center window, but rather removing and reinstalling to reseal. The short version is, it was a bear to get out. But after much prying and prodding, I did get it removed, with very little damage. And that was mostly bending the lip of the window frame slightly in a few places! I started this project as I was getting some water leaking in while towing the boat (on it's trailer) in heavy rain fall. I suspect the sealing material had shrunk up or cracked in a few places, just enough to allow heavy water to trickle in.
I am cleaning everything up well, and hope to reinstall the window & frame in the next day or two. What I want to know is if there is any reason why I couldn't use Butyl Rubber to reinstall the window & frame? Seems it would provide the sealing and waterproof properties necessary, while still allowing an easier time to remove in the future if necessary. Colby
