daninPA
- Joined
- Aug 16, 2020
- Messages
- 249
- Reaction score
- 1
- C Dory Year
- 1994
- C Dory Model
- 22 Cruiser
- Vessel Name
- NAVIRE
I had to do it all solo and found the lack of help positively reduced the pressure and divided mind.
srbaum":1jxj8x0i said:I use my trailers primarily on salt water and the standard thin wall steel guides had relatively short lifes. They are no longer heavily galvanized like years ago and even though I always rinse the trailer after use, the interior walls of the newer steel guides rot from the inside out.
After my last set failed, I went with aluminum. They are thicker wall, then the steel guides and after 3 years, see no visible signs of corrosion.
I used my existing PVC pipes and mounting hardware.
Look at this on eBay
(2)- 1 1/2" Square 1/8" Thick Aluminum Boat Trailer Square Guide On Poles PAIR, sold by Sturdy Built, Trailer Parts.
https://i.ebayimg.com/images/g/WEAAAOxy ... s-l200.jpg
daninPA":2s2yypz7 said:
Pat Anderson":sjfqaqan said:daninPA":sjfqaqan said:
It does not look like you got any responses to your question...I THINK with the extra long u-bolts these should work on my King Saltwater Trailer for guiding our CD25 on. The "goal posts" we have now are useless for sure. I would love to hear from anyone who has actually tried these and how they worked.
srbaum":lw4wftjw said:DaninPA,
My trailer has two sets of "goal post" and centering is absolute. The plus of these over what I had on my 22, is that I can wash and wax the boat, without them being in the way. On my 22, I had the longs carpet covered bunk board, mounter on two heavy gage galvaized steel post, similar to Wesley & Karen's boat. They performed admirably, but required removal for washing and waxing the boat.
http://www.c-brats.com/modules.php?full ... _photo.php
srbaum":sm6ih4kx said:DaninPA,
The post DO prevent the boat from drifting over the fenders. Additionally, the wooden boards, that is carpeted, inside of the fenders was replaced with 1/2” King Starboard, which also aids in centering.
srbaum":1cnp7lke said:DaninPA,
srbaum":renwpoza said:Pat Anderson,
My trailer is rigged like ssobol's, regarding the boat between the fenders. The plywood was swollen and the carpet on top of that made the fit of the boat too tight. I fixed it, by replacing the plywood with King Starboard, so now it glides between the fenders like butter.
http://www.c-brats.com/modules.php?set_ ... _photo.php
