Perhaps someone here will have had some experience with this.
I have a fuel storage tank, with a capacity of 125 gallons. Until now, it has been used to store diesel fuel. I want to use it for gasoline. In its past life, the tank sat at a construction site where it was used to refuel an excavator. It would get refilled from a tank truck. Where it is now, it will remain stationary. It will be refilled from a fuel barge.
The tank has about half an inch of diesel covering the bottom, to that means there's probably a couple of gallons I'll have to get rid of by perhaps tipping the tank to it runs to one spot where I can siphon it out. The tank has a mounted hand pump, and all the fuel the pump can reach has been removed.
My question is, once the tank is essentially dry, can I simply fill it with gasoline, or must (should) I endeavor to clean out the tank to remove any diesel residue? The tank has one of those large cartridge-type fuel filters on the hose, and I can still see diesel in the plastic cylinder. I'll dump that and insert a new filter.
I have read that a diesel tank can be washed out with water and TSP (tri-sodium phosphate), but then getting the interior to dry can be a problem, although I understand that denatured alcohol can help. Should I go that route, or will I just create work for myself and open the door to unforeseen problems associated with putting water and cleanser in a tank designed to hold fuel?
