Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,963
- Reaction score
- 298
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Borris, I moniter all wheels and tires with IR thermometer including the RV and truck tires when towing. It takes no longer to walk around and hit the hubs with the thermometer every 2 hours, wheels/or discs, tires with the IR therometer than just to walk around. If you have a drum or disc dragging, it should be picked up. Same with inspection of tires and all running gear. One of the few times I violated this rule and went 4 hours, I ended up with a problem...
I can give you the "company line" from bearing buddy:
"BEARING BUDDY® VS. OIL BATH
Some trailer manufacturers are offering an oil bath system as an alternative to a standard bearing protector, such as Bearing Buddy®. They claim that since long haul trucks use this system it must be a superior system to a grease packed hub. What they fail to recognize is that America's highways are the perfect environment and application, as the constant miles and tire rotation keeps the bearings well lubricated. Boat trailers, however, operate in a completely different environment. The hubs on a trailer can heat up during long trips and when they are dipped into cool lake water, the sudden temperature change creates a vacuum inside the hub. This vacuum will draw any condensation, moisture, or impurities directly into the bearings, which can cause premature bearing failure.
Standard bearing protectors, such as Bearing Buddy®, make it easy to visually check the amount of grease inside grease packed hubs. The internal spring piston exerts about 3 p.s.i. against the grease to ensure that no water enters the hub when the hub is submerged during loading and unloading. When properly maintained, there are no voids inside the hub where condensation can form during wither storage.
By comparison, oil bath hubs should be checked after every loading/unloading cycle to make sure water has not penetrated and diluted the oil. Small leaks can cause the oil to escape and once this happens, bearing failure is quick and complete within a few miles. Most oil bath hubs are only half filled with oil and must be carefully inspected to maintain the proper level. Too much or too little oil could cause problems.
If a Bearing Buddy® is knocked off, it would still be possible to run for many miles without bearing failure. This would not be possible with an oil bath. Bearing failure would occur within a few miles.
The problem with moisture in both grease without pressure, and oil bath bearings has been reported in a number of the trailering forums. Again, i have no experience with the oil bath personally. But the hot cold cycles certainly will bring in water into bearings which do not have grease under pressure.
