ChapaRRal Cock":2drr6yth said:
Honestly, Bob, you were the one I was hoping would chime in. I have gone through your albums and realized you have done some electrical upgrading.
Why would you not put the batteries in the Hulls? I was going to build a platform and epoxy it to the hull to raise the batteries up and to be able to secure them. rogerbum on SEADNA cut an access hatch thru the floor in front of the captains helm that is where I was going to access and it would offset the water weight from my freshwater tank.
My apology, I missinterpreted in the your first post, that you were considering forward under helm foot rest area. I was going on your post:
. I was thinking about cutting a hole in the floor and putting the batteries in the sponson? I think that is what its called.
If you want to put the Lifeline 300 amp hour AGM batteries, up forward, --say under the helm area--that would be fine, if built up on a platform. The reason I suggested against it, was if they were to be put aft, there is an issue with getting the bilge completely dry with the Tom Cat. Not only water itself, but the high humidity in the hulls, tend to accelerate corrosion. If you are willing to inspect the batteries regularly, that would work. Unfortunately the Tom Cat tends to have a lot of weight in the stern--and that also affects performance. You don't want to get weight too far forward. These four batteries are 360#. How this affects the trim of your boat will depend on where other heavy items are located. In my boat the water tank was on Starboard, and I put the batteries amidships back in the cabinets.
Not sure how you were going to epoxy a platform to the hull, but here is what I did for the Lithium ion batteries I put under the aft end of the port side of V berth.
I cut out the plywood, and epoxied "cleats" around the edge which would not be against the hull or bulkhead. I then coated the entire platform with epoxy. Before putting in the boat--any "legs" going to the hull were cut from cardboard patterns I had made. They were also attached with epoxy to the plywood platform. Any area which would be in contact with the hull, and area where I would be putting 3" fiberglass tape, was cleaned of any amine blush and sanded lightly. I sanded the hull, and any painted wooden bulkhead, to give a good surface to epoxy to. I overlapped the glass tape equally over the platform, and the hull surface. I made a small fillet with thickened epoxy to give some radius and avoid a sharp transition at the joint. of the platform and hull.
Incidentally those Lifeline AGM are not the standard Golf Cart--they are over twice as expensive--and worth keeping. (Again, I didn't look up the specific battery, my error). These are 50% more capacity than the standard (about 205 amp hours) GG. Also weight is about 30# more. 30 gallons of water is going to weight about 180#. So be careful with trim...
