Well-known member
- Joined
- Oct 2, 2011
- Messages
- 5,131
- Reaction score
- 85
- C Dory Year
- 2009
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- UWH25301J809
- Vessel Name
- C-Traveler
Colby and Ssobol, That now seems to be the way mine is set up. For AC it goes through the AC panel. Where the GFI power source is (behind the fridge) the gfi says "for AC shore power only". Does this imply that I should turn the AC breaker off when not hooked up to shore power?
When the AC is off and the shore power is not connected the fridge still runs. even if the battery switches are off. I believe this tells me that the fridge is hot-wired to the batteries as there is no visible switch that turns it off the supply. How can I confirm that it is the House batteries and not the starting batteries?
I’m hesitant to reply on many electrical questions because without knowing how the boat is wired or a specific schematic, there really is no way of knowing. Too many boats, particularly used, are wired differently by their past and current owners and I’m not so sure even the manufacturers wire them the same. The only sure answer to your questions is to trace the wiring or speak with the previous owner to see if they might know. Generally all a/c switches should be off when connecting and disconnecting shore power. My frig does have a switch on the a/c electrical panel. All items on my boat, with the exception of the main starter battery cable, the Vectron Battery Monitor, the battery charger and the inverter, go thru the main battery switches. The inverter is turned on thru a relay with a switch at my 12vt panel, which again requires the main battery switches to be on. I know this because I rewired much of it and have schematics with my owners stuff that would transfer with the boat if I ever sold it. 8) Colby
