johnrmarshall22
- Joined
- Feb 22, 2008
- Messages
- 112
- Reaction score
- 20
- C Dory Year
- 2006
- C Dory Model
- 22 Cruiser
- Vessel Name
- Slack Time
Hi Guys, my first real post is unfortunately a question for you electrical gurus who can speak(type) in laymen terms to my dumb self.
New 2006 CD 22’ boat to me has some electrical glitches :? . First problem is that port and starboard (Honda 50s 2006) voltmeters read different. And I get low battery warning on GPS unit when idling, running radar, radio, GPS, Port engine charging just over 12 at idle, starboard 12.3. At 1500 rpm port barely 12.8 (checked at starter to ground to verify in dash meters ok) Starboard shows 13.8. I have two batteries that appear to be wired dedicated to each engine, are same, one (port brand new) and starboard is less than year old (same size/ type). Electronics add-ons installed by previous owner (Radar, GPS, radio, Wallas appear to be running off port engine – separate fuse panel). It seems that if anything the port engine would have greater demand therefore be charging at a higher rate even at lower RPM. If running at 3500 and beyond the voltmeters on both engines are about even at just about 14 volts – but port is a little lower. In general I suspect the wiring that was done by a non-electrician and is not the optimum configuration, and / or the alternator or regulator on the port engine is not functioning normally.
Next issue, my starboard tachometer suddenly goes off while running intermittently. When I shut engine off then re-start engine tack works for a while. I suspect loose wire/ connection/ corrosion. Looked behind tack, appears clean. Just for giggles I unplugged main wire harness/ coupling at front of engine to see if corrosion might have been issue… no change, no corrosion.
Be gentle guys with technical solutions…. I could get over my head real fast with this electrical stuff. Thanks in advance!
