Roy & Dixie
Sunbeam...your recollection is correct...the replacement rectifier is twice as big.
Due to the fact that the seller has offered to cover 1/2 the cost of the new R/R, I plan to get the newer version rather consider the used one.
Was there a fit problem with the larger deminsions of your replacement unit? I assume the heat sink attaches to the original mount with the same 2 small bolts. Is the new unit taller or wider?
