Donald Tyson
- Joined
- Jul 24, 2023
- Messages
- 712
- Reaction score
- 15
Anyone using the West Marine roll up RU250? They’re 599.
thataway":1m9yiemv said:We have owned both the 6 1/2 (too small)' and this 8 1/2' versions. The slats in the floor can break or crack. Our solution was to basicaly re-make them using fiberglass and epoxy. To get the best stability then make a 1/4" plywood "floor" to go inside as it is pumped up.
We used both a Torqeedo and a Suzuki 2.5 hp outboard. They are lightly built and you don't want to drag over sharp rocks. You could glue a secondary protective layer on the bottom if necessary.
We used ours in AK and being careful there were no problems taking the dog ashore at least 4 times a day.
thataway":254m8pwn said:We have owned both the 6 1/2 (too small)' and this 8 1/2' versions. The slats in the floor can break or crack. Our solution was to basicaly re-make them using fiberglass and epoxy. To get the best stability then make a 1/4" plywood "floor" to go inside as it is pumped up.
thataway":3b0nd6y3 said:How would you propel a dinghy? The motor is going to cost more than the dinghy. Oars? (or paddles as these are more likely akin to) are not adequate for a head wind. Once I had a 2 hp on a 12' inflatable. I was going down wind at San Miguel Island, As I turned to go to the boat, I realized that the the outboard full out would not push the boat into the. Fortunately Marie had a line she threw to me, as I slowly went past the stern, outboard full open throttle.
I once rescued 4 divers and their gear at San Miguel, when their outboard would not push them against the wind. Eventually the boat swamped and the outboard stalled. They were stranded on a rock. The wives were panicked. They could not reach CG on VHF, I took them 2 at a time, with a little gear to their boat. I had 25 hp on the 12 foot inflatable, which was enough to push against the wind. Ironically those who were stranded were physicians from a nearby city. Each "Anniversary" they sent flowers and a bottle of wine to my office. They would have been in serious trouble if some boat had not come along. Even with wet suits, the chill factor, no water etc could have taken a toll. The other factor was that the wives were not capable of handling the 50' power cruiser they were on. This is only one of the reasons I advocate so strongly that your partner or some person aboard has to be able to operate your boat in the case of an emergency!!!
