Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,946
- Reaction score
- 291
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
I am getting ready to put electric over hydraulic brakes on the "new" trailer.
There are three E/H actuator's available:
Hydrastar,
Titian (BrakeRite),
Dexter.
There are adaptors for the factory in cab brake controller by Hydrastar and Titian, (which are necessary for the GMC Yukon). The RV will have a Tekonsha Prodigy brake controller. I suspect that either of the adaptors will work with the Dexter, but not "official".
All are 1500 to 1600 PSI for disc brakes. The titian has a plastic cover (which alone is not a concern, but lack of weather sealing may be an issue.
All of the units/components will be mounted above the trailer frame to avoid immersion during launch. (either on a stand, or on the tongue pedestal).
I will be putting in a "wash down" system, which will use a garden sprayer with "salt away" for immediate wrinse after launch, spraying directly onto the calipers and rotors.
Which actuator brand should I go with and why?
I am considering both Trailer Superstore, and E-Trailer supply--any experience with these? E-trailer had some complaints at "pissed customer"--Eastern Marine trailer superstore…none I could find. BBB, Eastern Marine A+, E-trailer no rating.
I'll make a note--I had considered plain electric brakes, and I may put them on the Caracal, which does not require brakes because it is less than 3000 lbs But the E/H Discs have a history of better stoping power, than electric brakes--as well as the concern about corrosion and being far easier to wrinse off after use.
Hydrastar,
Titian (BrakeRite),
Dexter.
