Cockpit and deck paint
I work extensively in Brazil with the forest industry and universities. Brazilian Koa is neither Koa or Acacia. The botanical name is Astronium fraxinifolium (sometimes Astronium graveolens), commonly called"Gonçolo alves" or sometimes Tigerwood in Brazil. It was initially marketed as Tigerwood. When marketed as "Brazilian Koa" it sells better and for a higher price, because of Koa's reputation. This is kind of like calling Patagonian toothfish "Chilean Sea Bass" and shark meat cut into round pieces "Scallops".
However, this wood is generally a great product, very hard and rot resistant. However, it does vary in quality, hardness and price. It has "arrived" as a product, so it is not quite the bargain that it used to be when marketed initially as Tigerwood. Key is to get a look at the product before buying if you can.
Rob, Thank you for your expertise on woods. It is a pleasure to have someone aboard with your knowledge. Few things more beautiful than premier wood workmanship...on a boat....especially if some else maintains it!
I used a product called Tuff Coat, it was the smoother texture option . Ordered from Amazon with the epoxy primer. Used on the horizontal surface where the sunlight UV had caused the gel coat to craze. Been on a year so far, holding up very nicely. And the texture looks great. A water based product, applied with a special roller from the manufacturer.
Similar to a product called Kiwi Grip.
