Cockpit rails for 22
kaysea
We haven't bought our 22 yet, but are getting close; we're busy considering all the options.
I've learned that C-Dory uses the same cockpit rails that are on the 25, for the 22. We like the 25 rails (the way they turn the corn at the stern), but are concerned about the height of the rail.
Anyone aware of alternative similar but shorter cockpit rails?
Are you ordering a new 22? If so, I'd suggest contacting the factory to confirm what you were told about the rails...it could have just been a misinformed sales person, depending on where you were shopping. Greg Little at NMI will likely get back to you regarding actual current production specs...some things have changed with the current manufacturer from years past, and as we learned at the factory tour last week they continuously make minor tweaks and improvements, so it might be different with current production.
If it turns out that the option rails are indeed the same as the 25' and you want them shorter, then I bet you can work with C-dory and/or PDR Marine aka Pooderbuilt.com (where the rails are made) to have them made shorter to your liking.
I too would think the 25' rails would be too high for a 22' which is why I question what you were told. What I want for mine is one of those rails that simply goes straight across the splashwell I've seen in many albums, good for mounting BBQ and other accessories. I need to research if that was a factory option or a custom part...
Welcome to the C-brats, and congrats on your pending purchase! It's a fun process for sure!
-Mike
Pretty much going to echo Mike above. I've never seen the cockpit gunwale rails standard (or even optional) on a 22, but that doesn't mean they aren't offering them now. It's also not at all unusual to have custom stainless rails and the like made; so either way I think you should be able to get what you want.
Thinking about it, I'm not even sure the 25 rails would fit on the 22. I'm not looking at them or my boat right now, but I think they curve around at the topside-to-transom interface and that's right where the lazarette lids are on the 22.
Be interesting to hear what you find out when you check back with them.
And... new 22! Whee! :thup
The reason rails were put on the 25, is that the cockpit floor is about 8 to 10" off the bottom of the boat. Thus the cockpit combing would come close to hitting many folks at the knee level, rather than mid thigh. This is a safety issue.
I also have not seen side rails on the 22. The 25 has seats aft, where there is a Lazaretto (batteries, electrical, storage, bait well)--and I don't see any reasons to have railings there--where as in the 25, you can lean back against the railings as you sit in the two corner seats.
To me railings on the side of the 22 would be a hinderance--especially in getting in and out of the boat. Although the cockpit in the 25 is only 2' longer on the floor--functionally it is longer because of the corner seats.
It is very easy using off the shelf components to put railings across the splash sell. I had a railing in the 25, In the below photo you can see the railing I put across the cockpit, to help hold the generator and ice chest etc. Also note how the railing makes a seat back. That railing could be moved up or down, back or forward--just a SS 1" tube and a couple of SS Bimini top fittings and deck mounts.
If you don't like the alternatives presented to you by the manufacturer or dealer, simply buy the boat and then take it to a railmaker.
These folks custom build all kinds of stainless railings for sailboats, fishing boats, commercial boats, law enforcement boats, and so forth.
They can build anything you want to your specifications.
Why deal with limited choices?
I, too, would be concerned with the added difficulty of getting into and out of the boat with a railing. I'm sure they could add some sort of a gate on each side for you and make it look good, too!
Good Luck!
Joe. :teeth :thup
Thank you, Seawolf and Thataway, for your replies.
Based on the concerns voiced by you experienced C-Brats, we'll wait on the cockpit rails, until we've used the boat for a while. Accessibility is an issue for us; your posts made us realize we need some experience with our boat to be sure the rails won't make things harder, rather than easier!
Further comments welcome! Thanks!
Good decision. Also look at how other C brats have handled the getting in and out of the cockpit--with additional steps--That first step is a long one for many people! Generally it is good to use the basic boat for at least a month or two, before making any modifications. Then take what others have done, and modify to fit your needs.
One example of what I have done on each of our boats is to add a short hand railing on the outside aft corner (the the lip, not the cored top) of the cabin top. The rail on the aft bulkhead is helpful but if pulling up-the extra railing higher really helps us.
One could also make a railing, which can be removed and is more of a grab bar on the side of the cockpit--think 18 to 24 inches above the deck. --just as a hand hold. There are some made for fishing rod holders.
Nancy and I have been pouring over all the photo albums here to get ideas on how we can make the boat more useful.
C-Batical's photo album included this photo which looks like a pretty slick idea on how to have a stowable step in the cockpit.
The generosity of C-Brats is simply amazing.
