AKMel
- Joined
- Jan 13, 2017
- Messages
- 53
- Reaction score
- 2
- C Dory Year
- 2008
- C Dory Model
- 22 Cruiser
- Vessel Name
- C-esta
Summers we boat in Southeast Alaska, surrounded by water in a temperate rain forest. Water temp typically 50˚or less. A problem we experienced each trip was lots of condensation in the cabin. Windows especially sweat.
-- Up front we have a 6” fan on each side facing the forward windows. When underway and on “high” they barely keep the front windows condensation-free on cool days.
-- The boat is garaged with windows open when not in use. The problem exists most after the first night aboard.
-- I installed an Espar heater, which works well, and set it up so the combustion air comes from inside the cabin. This should draw in fresh, less-humid outside air and dispel moisture laden air out the exhaust. I couldn’t tell much difference in the cabin condensation.
Saw this product on-line: “Eva-dry EDV2200.” The EDV2200 is a mid-sized capacity, electric dehumidifier. The unit works in areas of the home that are up to 2,200 cubic feet and helps dry the home via thermal electric Peltier technology. It's effectiveness is measured in gathering approximately 20.5 oz. of water per day at 86° F and 80% R.H. Additional specifications of the EDV2200 include: a power adapter of 12V DC 6AMP, power consumption of 72W, 2 Liter capacity removable water tank and an automatic water level detector switch to indicate tank is full. The unit measures 8 ½"W x 14"H x 6 ¾"D."
Cost $85 on Amazon. Anyone tried this?
I’m thinking the power adapter can be bypassed to run directly off 12v. The power adapter is 6amp, so I suspect it draws a little less??? I’m guessing overnight use should consume 40-50amps 12v. The downside seems to be that the unit will freeze up at 55-60˚. But with a cabin heater that should not be a problem for us.
Your thoughts appreciated. Mel
