Still working away on my little 16' Angler. One of my projects is to get the kicker tied in to the main outboard so that it can be steered from the helm. I thought I had it with a piece from Cabelas that joins them with a threaded, stainless bar at the front. They call it an Auxiliary Motor Connector Rod.
I was looking at my motor set up today and I'm thinking now that it won't work because the main motor is mounted on the stern of the boat while the kicker is mounted off of the stern on kicker bracket. I think they have to be mounted on the same plane for the bar to be able to reach from one to the other. It mounts on the front of the motors and can be attached or detached while underway. The props are at about the same plane when both motors are in the water and it almost seems like I could run some sort of bar between the two motors just above the props on the horizontal fin just above the prop. I'd have to drill a hole in the fins. Another issue would be that it wouldn't be the easiest thing to set up while you were under way. It would have to be done at the launch. What have others done?[/img]
