- Joined
- Nov 2, 2003
- Messages
- 8,561
- Reaction score
- 1
- C Dory Year
- 2005
- C Dory Model
- 25 Cruiser
- Vessel Name
- Daydream
OK, I need to know the Amp Hour (AH) rating for my house batteries, which are two NAPA Premium RV/Marine Deep Cycle batteries wired in parallel, in order to set up my Victron BVM 700 battery monitor. Each battery is rated at 160 minutes Reserve Capacity. The Victron BMV 700 (picked it up yesterday) needs to be set to the actual capacity of the batteries in AHs.
So I THINK I get there this way: Add the RC of each battery separately to get total RC. 160 + 160 = 320. Divide RC by 2.4. 320 / 2.4 = 133.33 AHs. The Victron defaults to 200 AHs on startup, so I will have to lower the setting to 0133 (four digit display). Agree, or am I missing something here?
The "divide by 2.4" is an alternate method that gives the same results as the technically correct method (copy and paste from eHowTo.com):
Instructions
1
Multiply the reserve capacity by 60 to convert it to seconds. For example, if a battery offers a 100-minute capacity: 100 x 60 = 6,000 seconds.
2
Multiply this length of time by 25, which is the battery's amperage. Example: 6,000 x 25 = 150,000. This is the number of Coulombs of charge in the battery.
3
Divide this answer by 3,600, which is the number of Coulombs in an amp-hour. Example: 150,000 ÷ 3,600 = 41.67. This is the number of amp-hours in the battery.
Tips & Warnings
To convert in a single step, divide the reserve capacity by 2.4.
Instructions
1
2
3
Tips & Warnings
