Roy & Dixie
There's always something. Yesterday while sea testing PermaTrim installation on 1999 F80 Yahama, I noticed no water flow from indicator that should have been been squirting a steady stream of water, and my interior gage had no reading. I checked the small hole to be sure it was not clogged. It was not. I even pulled the small hose off the outlet jet and, with the engine shut down, could blow back through the tube into the cooling system. The water jackets were cold. After I restarted the engine I could see water exiting ports on lower areas and water ran freely from the garden hose flush connection. The water jackets stayed cold and a little water flowed from the indicator line but ceased as I increased speed. I called the service dept manager, involved in the original sale. He said I should be ok, that silt was probably involved in stopping up the small tube. He said I would get over heat alarms long before any damage would be done. I cruised 2000-3600 rpm for 3-4 hr. Engine and water jackets remained normal temps.
I watched youtube instructions on installing a new impeller and feel this is a DIY project, but I want to eliminate any other possibilities to correct the flow problem first. Any thoughts??
