When I put Capt's Choice in the water last weekend (on Saturday) had good flow from both Honda 45 telltales. I've periodically had to push a little wire up the hole to get that but they were just fine this time.
On Sunday when I went out, about an hour out in the River, I noted that the Stbd engine had no telltale flow. I stopped, attempted to get it flowing but had no luck. Took off the engine cover, removed the rubber hose from the spout and tried to get that cleaned. No dice!
Even though I had no water there, the engine was obviously getting cooling, no overheating indications, I know the warnings work because I had a pump failure last year and the red light and buzzer came on!!
Any ideas of cause/cure?
Thanks - Charlie
Thanks - Charlie
